Author: Subject: Which tyre size
smart51
posted on 9/3/06 at 08:22 AM Reply With Quote
Which tyre size
I had an idea last night. I'm thinking of fitting 13" wheels to my car instead of 15". I was going to use 205/60 tyres as they have the same rolling circumference as the 205/50 that I have.
If I fit smaller tyres then I will have slightly lower gearing, giving better acceleration at the expense of a lower top speed in each gear, not that the top speed in each gear is particularly low in a BEC. I have found two sizes of tyre that are available but I don't know which would be better.
195/55/13 or 195/45/14
OK so there is not a lot in it. Turns per mile are within 2%. 14" will fit over a sierra rear caliper easier, 13" may be lighter. They are slightly different profiles.
Which would be better or worse and why?
NS Dev
posted on 9/3/06 at 08:47 AM Reply With Quote
I would go for the 13" ones. They will be lighter, and more importantly, you don't want 45 profile tyres on a 7, the sidewalls on most 55 profile tyres are too stiff for these light cars, 45 profile would be far too stiff, no progression and like driving on ice.
ned
posted on 9/3/06 at 09:15 AM Reply With Quote
i've got 14's at the moment but am leaning towards buying a set of 13" rims to get the weight down. i recon 185/60 front and 205/60 rear for my car, you might want something slightly smaller on the rear perhaps?!
Ned.
beware, I've got yellow skin
procomp
Hi if you want i have various 13's of the race car you could just bolt them on for a quick run and see what you get.
they are all either 048 or 032 so would need to be dryish for you to try them whithout spinning but your welcome to see what gearing you get.
cheers matt
(Edited to say same as nat 13's always except for brake clearence probs)
[Edited on 9/3/06 by procomp]
NS Dev
posted on 9/3/06 at 09:30 AM Reply With Quote
Ned.
Ditto except that I have 15" (pug alloys) at the moment, cos I have a shedload of em laying around. Really need to get some 13" ones tho!
