Author: Subject: chopping diff mounts
locoboy
posted on 12/3/06 at 03:53 PM Reply With Quote
My 7.5 inch Cossie LSD needs taking down to 7 inch to fit in my GTS diff mountings.
Do I
A) lop 1/4 inch off each side of the top mount on the diff?
or
B) lop 1/2 inch off the side with the most meat on it!
Im leaning towards option A myself as it keeps things central.
And how do i go about doing it? has anyone else done it?
Locoboy
nludkin
posted on 12/3/06 at 04:22 PM Reply With Quote
I lopped 1/2 inch off mine and it breached the diff casing, so I ended up buying a 7 inch one. However, in the future I think I will get a mount made especially for the 7.5 inch one.
For something as critical as the diff I personally think a custom bracket is the safest option.
Mix
posted on 12/3/06 at 05:00 PM Reply With Quote
I don't know how wide the GTS tunnel is but the clearance for the UJ may be an issue with option B. I'd go for A, as you say it keeps things in their correct orientation, and negates the possibility of chopping the driveshafts.
Mick
posted on 12/3/06 at 05:15 PM Reply With Quote
Got to be option A - assuming it can be done. Option B will give you all sorts of problems.
locoboy
posted on 12/3/06 at 05:23 PM Reply With Quote
If it cant be done then she may be for sale!
[img][/img]
Locoboy
Liam
posted on 13/3/06 at 02:24 AM Reply With Quote
I thought the extra 1/2" is all on the nearside on a 7.5" diff, which means it'd have to be option B to keep things central. Could be wrong though as this is just off a CAD drawing I have (but didn't do myself). Compare the top mount to the bottom mount. On a 7" diff both mounts are 7" and central. Have a look on your 7.5 - if the top and bottom mounts line up on the offside then all the extra meat is on the nearside. Or just find the centre of the diff at the top mount (casting line on the 7" diff) and measure 3.5" out from each side, and thats where you need to chop.
But beware as i've seen a couple of attempts to do this end up with a hole in the diff. Better off moving the mount on the chassis, but if I were you I'd be selling that large-flanged-fat-shafted heavy beast for the appropriate cossy tax and get yourself a nice cheap 7" LSD with sensible sized shafts too.
Liam
posted on 13/3/06 at 05:55 PM Reply With Quote
Option C is the only realistic option, move/modify the brackets on the chassis to fit.
