posted on 22/3/06 at 02:56 PM |
arrgggghhhh!!! that's gonna lose me a day
the more observant would remember I was looking for a spring for the brake pedal.
last night took a good look at it and when I move my steering column, the bolt head for the bolt that holds the brake push rod to the pedal is ever so
slightly catching on the column. Not much but enough to prevent the pedal coming all he way up so the brake lamps are on!!!
bugger!! why didn't I spot it at the time??? It's gonna take a few hours unding the column bracket, saltk switches etc to move the
cooumn out of the way so I can get the bolt and shave its head down a bit. bugger again.
NS Dev
| posted on 22/3/06 at 03:22 PM |
10 mins work, no bother
Danozeman
| posted on 22/3/06 at 03:23 PM |
Bugger
Dan
| posted on 22/3/06 at 03:27 PM |
bouble bugger and arse as well - very annoying when you have to do something again
DarrenW
| posted on 22/3/06 at 04:55 PM |
easily sorted. Nowt to worry about, shouldnt take long to fix. What are you going to do after 7.30??
Unfortunately these are the sorts of things you come across putting an unfinished project right as you cant get into the head of the original builder.
Hopefully you wont have too many more and soon be well on the road of completion.
| posted on 22/3/06 at 06:51 PM |
Use a clevis pin and split pin , correct parts for the job ! Clevis will have a very thin head to it
| posted on 22/3/06 at 09:07 PM |
yeah, did wonder about that; having the push rod rub on the threads did not seem too clever to me; at a push I could use a bolt rather than the set
screw fitted.
Now ofcourse my question has to be what size clevis pin and where from? (nut for the bolt is 17 mm AF)
| posted on 22/3/06 at 09:10 PM |
you have a good memory.....
this is rather self inflicted; to fit more comfortably I raised the steering wheel that move the column to the bolt. Easy to fix just gonna be fidly
undiong the nuts/bolts andthen even more fidly to do them up again; there is not much room to swing a spanner.
Incidentally, maplins sell a stubby spanner set that is ideal for this type of limited access work - not the best quality but then you wouldn't
be able to crank up the toruqe high with them; sometimes they are on special offer; think I paid £ 10 for mine.
| posted on 24/3/06 at 08:21 AM |
sorted last night took 2 hours and 6 minutes
hopefull will get the rear lamp cases made up the w/end and finish of the nose cone.....
