watsonpj
| posted on 28/3/06 at 10:54 PM |
Fury front lower ball joint
Anyone know the part number of the old fury lower front balljoint (sherpa track rod end). Fisher told me QH qr201rth. My local car shop gave me an
equivalent fr4071 but the tapers wrong size (OD) and the thread is too small. Its marked up as a landrover part.
Also I've had both of these go at the same time in the same place (at the inboard edge) is there a design problem around this area? It looks
like the lower wishbone angle causes a constriction around the rubber causing it to wear. I was thinking of cutting an angle on the lower edge of both
upright (5-10 degrees) to try to reduce the problem. Has anyone else seen this issue and done a mod?
I need to get this fixed ASAP as the sun was out today and my cars in bits
stevebubs
| posted on 29/3/06 at 01:13 AM |
Lucky bugger....rained here all day today!!
Don't know the answer to your question I'm afraid and it's not in my Sylva build manual.
Best place to ask this question would be the list below, or ring Sylva and ask Steve to check with JP....
http://groups.google.com/group/Sylva-Chat
