Author: Subject: M/C Resevior below brakes problem?
MikeR
posted on 29/3/06 at 11:10 AM Reply With Quote
I've got a vague memory that having the master cylinder resevior below the brakes causes problems with fluid seaping back & bleeding the brakes.
Am I remembering rubbish?
Just about to buy pedal box off stuart taylor and there m/c have the integral fluid resevior. Ian says its not a problem but i'd like some independent reassurance.
NS Dev
posted on 29/3/06 at 11:13 AM Reply With Quote
never been a prob on the grasser and the bottles on that are slightly below the calipers.
shortie
posted on 29/3/06 at 11:34 AM Reply With Quote
I had to turn my rear calipers upside down to bleed the system properly, I think a few people have had to do this.
Rich.
NS Dev
posted on 29/3/06 at 11:46 AM Reply With Quote
that's cos the bleed nipples weren't at the top of the caliper, different problem to what Mike is asking
MikeR
posted on 29/3/06 at 11:51 AM Reply With Quote
NS Dev - what are you fitting to the seven, remote or integrated reseviors?
jimgiblett
posted on 29/3/06 at 11:57 AM Reply With Quote
Some people use RPV such as THESE
to overcome problems of master cylinders below the calipers causing excess pedal travel.
Havent done it myself yet but am considering it as I like a very firm pedal for track use.
- Jim
[Edited on 29/3/06 by jimgiblett]
Liam
I remember reading somewhere that if the reservoir head is below the calipers then fluid can indeed flow back a little causing you to have to double-pump the pedal if there's been sufficient time for that to happen. No problem with the mcs being low, but i'd have higher mounted remote reservoirs if I was doing that.
Liam
posted on 29/3/06 at 12:27 PM Reply With Quote
Not a good idea.
NS Dev
posted on 29/3/06 at 12:31 PM Reply With Quote
Remote "one" Mike, Clive's doing me a triple stainless one to feed both brake cyls and the clutch one.
MikeR
posted on 29/3/06 at 05:21 PM Reply With Quote
oh yeah, i forgot!
Danozeman
posted on 29/3/06 at 08:37 PM Reply With Quote
Is the problem really that bad? Iv just fitted my mc and res low down...
Dan
NS Dev
posted on 29/3/06 at 11:28 PM Reply With Quote
I wouldn't panic.
Virtually every competition car that I have seen recently has the integral cyls lower than the calipers.
Just started doing some servicing and pit crewing for a britsports team running a radical and they are very low in that and seemed to be working fine last weekend at silverstone!
MikeR
posted on 30/3/06 at 07:59 AM Reply With Quote
And just when where you going to mention that (and get me my free pit lane passes - two please then i bring Paula)
NS Dev
posted on 30/3/06 at 08:55 AM Reply With Quote
It's only just come about really, time never seems to be there for me but I am supposed to be helping out getting the car ready for the next race, which is not this weekend but the next, at Oulton.
Had a lot of teething troubles including blowing a brand spankers powertec 1500 hayabusa (gearbox mistake) and damaging some poorly repaired bodywork. Car is good though, on the pace when things were going well.
Don't think you need passes Mike, just wander in I think. You'll need tickets, may or may not be able to help out there, would have to see!
MikeR
posted on 30/3/06 at 11:15 AM Reply With Quote
Paula's in Finland with Holly for the next couple of weeks so it would just be me if i can spare the time from the seven!
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 30/3/06 at 06:39 PM Reply With Quote
Resovoir Position
I always mount my resovoirs low, below the caliper hieght and have had no problems. The pedal is always rock hard.
You may have a problem if you mount the resovoirs below the master cylinders though.......
John
MikeR
posted on 30/3/06 at 06:56 PM Reply With Quote
damn looks like i've "wasted" about 30 pounds then.
ho hum.
Danozeman
posted on 1/4/06 at 12:18 PM Reply With Quote
Right ill leave mine where it is then and see how it goes. Can always fit some of these check valve things if theres a problem.
Dan
