Author: Subject: Differential oil
JoaoCaldeira
posted on 11/4/06 at 03:41 PM Reply With Quote
Differential oil
Hi all.
What are you using for the Sierra diff?
Thanks,
Joao
posted on 11/4/06 at 04:30 PM Reply With Quote
EP90 hypoid, no sawdust .
stevec
posted on 11/4/06 at 04:35 PM Reply With Quote
Wilkinsons do it for about £2 a ltr, Comma stuff.
chrisf
posted on 11/4/06 at 05:03 PM Reply With Quote
Redline lightweight
posted on 11/4/06 at 05:12 PM Reply With Quote
It's a bit far from Portugal to the local high street though, eh Joao?
Krismc
posted on 11/4/06 at 08:40 PM Reply With Quote
How much does it take to fill a diff, roughly!!
JoaoCaldeira
posted on 12/4/06 at 07:54 AM Reply With Quote
Uummmmhhhh
a weee weee bit
Thanks for the replys.
I was wondering about semi vs. synth
Joao
chriscook
posted on 12/4/06 at 08:28 AM Reply With Quote
I'm using the Ford stuff in my sierra lsd.
NS Dev
posted on 12/4/06 at 01:14 PM Reply With Quote
plain non synthetic EP90 is what you want, around a litre iirc
smart51
posted on 12/4/06 at 01:27 PM Reply With Quote
You should fill the diff with enough oil to just reach the filler hole when the car is level. This is about 1 litre. I bought 1 litre and put it all in. Hypoid 90 differential oil is what Haynes says to use.
Dave J
posted on 12/4/06 at 01:48 PM Reply With Quote
Is the Hypoid 90 ok for the LSD as well?
Dave
NS Dev
posted on 12/4/06 at 02:28 PM Reply With Quote
yep if you are talking about a sierra one, as the lsd is sealed and seperate from the main gear oil in there.
With the old salisbury plate diffs like the capri atlas ones, you still use EP90 but add an LSD additive which affects the way the plates work somehow.
The additive is the stinkiest stuff you ever smelt, in a new sealed bottle it smells from 20m away.
Dave J
posted on 12/4/06 at 03:59 PM Reply With Quote
Yes we are talking Sierra,thanks for the info Nat.
Dave.
