Author: Subject: Sierra steering column bolts - which?
JoaoCaldeira
posted on 7/5/06 at 07:24 PM Reply With Quote
Hi all.
Which bolts have you used to mount the Sierra steering column? M18? seems a bit drastic...
Thanks,
Joao
indykid
posted on 7/5/06 at 07:27 PM Reply With Quote
m8, and big washers.
you can use top hat bushes to fill the gap, but i left mine to allow a bit of adjustability.
hth
tom
GEORGE80
posted on 7/5/06 at 07:47 PM Reply With Quote
m10's and i packed it up with 3 large nuts bringing the steering colum out 60mm, better position for me
jeeby_man
posted on 7/5/06 at 08:37 PM Reply With Quote
i made a couple of top hat bushes at work with M8 capheads
Danozeman
posted on 7/5/06 at 08:44 PM Reply With Quote
iv used m10's with some spacers from a seat belt. They fill the gap perfectly.
Dan
JoaoCaldeira
posted on 7/5/06 at 09:40 PM Reply With Quote
Thanks for all your replies
Joao
andrew.carwithen
posted on 3/11/06 at 02:48 PM Reply With Quote
hth
tom
A while back, I bought a pair of aluminium top hat bushes from a member who made them to order (think they also listed on ebay from time to time.)
Does anybody know who it is as I would like to get some spacers made up to enable the column boss to be be mounted off the chassis bracket ?
Andy.
tks
posted on 3/11/06 at 05:27 PM Reply With Quote
made special bushes
+ M10 grade 8.8!!
Tks
caber
posted on 3/11/06 at 05:51 PM Reply With Quote
M8 and penny washers given it a good torque up and I can't budge it.
Caber
scotty g
posted on 3/11/06 at 06:51 PM Reply With Quote
I believe the sierra used M10 stud and mr SVA likes you to use the same as the manufacturer, I know of people that have used smaller and had a fail because of it so go BIG my friend!!
Cheers.
