Matthew_1
| posted on 16/5/03 at 06:00 PM |
Difference in type "n" and type "9" gearbox?
Is there any actual difference between the ford type 9 and type n gearboxes?
Also, I've found an XR4x4 for sale very cheap, would there be any advantage in buying that over a "normal" sierra - I already have a
zetec so the engine difference is irrelevant. Although the V6 might be up for sale if I do buy the donor!
geoff shep
| posted on 16/5/03 at 06:36 PM |
What, for the gearbox? The 4x4 gearbox has a transfer box for the propshaft to the front wheels - you probably want a rwd box.
You can pick up type 9 5 spd boxes pretty cheaply.
4x4 type 9 box:
stephen_gusterson
| posted on 16/5/03 at 07:00 PM |
type N ine
ok?
Its nowt to do with 4x4 oe rwd
btw - how the heck do you 4wd aspirators get that big protrusion in the car without a large bump by your left leg?
atb
steve
[Edited on 16/5/03 by stephen_gusterson]
Matthew_1
| posted on 17/5/03 at 08:05 AM |
I'm not really after the engine/gearbox as Ive already got that sorted, and have no intention of installing 4WD!
Given its £150 I'm more interested in all the stuff like discs/calipers (from rear), driveshafts, diff etc. I was wondering if any of these bits
were a bit more "heavy duty" having come from a supposedly more powerful car? Lowish mileage so the bits should be serviceable/
Liam
| posted on 17/5/03 at 11:02 PM |
You dont - you live with the large bump under your knee, as well as the propshaft running along your leg
Liam
Liam
| posted on 17/5/03 at 11:09 PM |
Matthew...
Snap up that 4x4 while you still can! The rear axle will give you disk brakes and better than that a highly sought after limited slip diff.
I'd be interested in some of the front axle gubbins too. Speedo cable would be awesome.
Only downside is the 4x4 has different front uprights - you'd want to get hold of a pair of 2WD uprights. Just get it for that LSD!
Liam
stephen_gusterson
| posted on 18/5/03 at 10:11 AM |
Liam
Looks like the mini tunnel is the biggest problem! Would be best to go on jouneys that dont need the clutch much...of have some kinda hand
clutch...
Is that your car? If so, it looks a nice job.
atb
steve
Liam
| posted on 18/5/03 at 10:49 AM |
clutch...
Not my car unfortunately - that's the beautiful V8 4x4 Dax Rush that was my inspiration in it's early stages of construction. The big
bulge is no problem at all really cos it's just about under your raised knee. I've had a little go in that car and you do have to twist
your foot a little to operate the clutch. Nothing uncomfortable and you get used to it quickly. My footwell will have a little more room than that
though - a Rush is narrower than a standard book locost in that area and the tunnel at that point is even wider than mine. I'm just glad
I'm short with small feet.
Liam
[Edited on 18/5/03 by Liam]
