welshboy
| posted on 25/12/06 at 02:43 PM |
bushes again sorry
hi all can anyone tell me if it would be better to put a washer both sides between the bush and the bracket or is it right how iv done it now
thanks
[Edited on 25/12/06 by welshboy]
stevec
| posted on 25/12/06 at 04:09 PM |
Looks correct, Washers should not be needed on the inside, the inside faces of the bracket should clamp the steel inner bush when the crossbolt is
tight. The Yellow bushes will then rotate on the clamped inner bush.
Steve.
[Edited on 25/12/06 by stevec]
