The Baron
| posted on 4/1/07 at 05:13 PM |
Camber adjustable (turn buckle type)
Has anyone ever converted a 'Book' set of front top wish bone’s to the fully adjustable type, so that they can be adjusted without taking
the suspension apart?
If so, how.
Cheers in advance,
The Baron
flak monkey
| posted on 4/1/07 at 05:21 PM |
GTS top wishbones are adjustable for camber without dismantling anything...
Sera
http://www.motosera.com
scutter
| posted on 4/1/07 at 05:53 PM |
Do you mean this type of thing.
ATB Dan.
Ivan
| posted on 4/1/07 at 08:31 PM |
I have used them on my top wishbones.
Not much more trouble than the standard design and they work a treat. See my build diary no 9 and 14.
The only disadvantage is they reduce the space for the spring although I had no serious problem with mine, just took a bit more care.
Phil.J
| posted on 4/1/07 at 09:40 PM |
Doing it this way does mean re-adjusting the tracking too after each camber change.
Phil
flak monkey
| posted on 4/1/07 at 09:42 PM |
Thats essentially the same design as the GTS 'bones
Sera
| posted on 4/1/07 at 10:43 PM |
Phil
Is there a design that avoids this, using Cortina/Sierra uprights I mean?
Marcus
| posted on 5/1/07 at 09:14 AM |
TextIs there a design that avoids this, using Cortina/Sierra uprights I mean?
I don't think there is - if you think about it, more negative camber would effectively give you more toe out. I'd never thought about that
till now and I've been on the road 2 years!
Marcus
Because kits are for girls!!
NS Dev
| posted on 5/1/07 at 09:54 AM |
same on any wishbone setup with steering, you must always reset toe once you have adjusted cambers.
