Dick Axtell
posted on 16/5/02 at 06:12 PM |
Wheel Studs
To all you experts -
What's the recommended wheel stud length for alloys? These will be Ford Capri Laser 4-spoke RS type. Existing studs are 25mm from axle flange
face.
Dick
Dick Axtell
posted on 18/5/02 at 05:26 PM |
So nobody's expert?
I assembled & checked the rear hub, drum and wheel. The wheel nut/stud thread engagement was approx 0.625", (using the old studs), which should
provide sufficient retention for road use.
However, if anyone knows better - don't keep it to yourself!
Dick Axtell
bob
| posted on 18/5/02 at 06:33 PM |
Dick
I think 25mm would be the short studs as the ones on my sieera gear are 40mm and are the only 2 sizes i've seen.
Thats ofcourse unless anyone knows better.
