theohighland
| posted on 18/1/07 at 05:50 PM |
pedal box - master cylinder???
hi,
i have a sierra pedal box and master cylinder to go with it, but i'm trying to use as many escort parts as possible,
so i was wondering if i got myself an escort pedal box, would the master cylinder i have go with this?
or is it easy enough to use the sierra one anyway?
cheers, Theo
oliwb
| posted on 18/1/07 at 07:37 PM |
Can't think of any reason why the master cylinder wouldn't fit the escort pedal box. You'll probably have to play with brackets and
a like but then you need to with the sierra one as you no longer need the servo! Oli.
westcost1
| posted on 19/1/07 at 11:43 AM |
i was going to use a mk5 escort master cylinder but with the peddle box but the m/c was to big to fit under the bonnet so i used a axgt one i had a
bit smaller and fits a treat. i also had to play around with the spacing on the pedals to get them to fit as they were to wide.
And got in the way of the steering column. Got there in the end.
