Author: Subject: cheapest sierra cv joints?
richard thomas
posted on 10/2/07 at 11:13 AM Reply With Quote
Ok, so i'm going to bite the bullet and replace all of my rattly cv's....
Where is the cheapest place to get new or recon ones from?? or even whole driveshafts?? (lazy boy)
Cheers, Rich.
TimC
posted on 10/2/07 at 11:15 AM Reply With Quote
If any of mine are U/S I'm going to be gutted having stripped, inspected and painted the 'kers!
Fingers firmly crossed.
richard thomas
posted on 10/2/07 at 11:18 AM Reply With Quote
I know, that's what i did only to have them sound like marracca's. Difficult to tell, I thought mint felt ok on assembly...all nicely painted too
TimC
posted on 10/2/07 at 11:22 AM Reply With Quote
Good job I've not seen the car on the move, I might want to samba! (Or err, not.)
richard thomas
posted on 10/2/07 at 11:25 AM Reply With Quote
Just realised, you've never been in it yet...need to sort that out to make you realise your tragic engine choice error!! Only kidding, have to sort a visit out.
dern
posted on 10/2/07 at 11:30 AM Reply With Quote
Get them from your local motor factors.
You can buy the cv joint separately for about 20 quid each. You should be able to either get the joint in a kit with the boot and a bag of grease or buy all the bits on their own. This is what I did on my westfield because they are westfield's own shafts which are shorter than sierra ones. Taking them to bits and reassembling them with new cv joints is easy but messy. Don't lose the clips though.
The other option is to take both entire driveshaft to your factors and exchange them. In this case you'll pay about 50 quid per driveshaft and you'll get a fully assembled painted recon driveshaft in return... all you have to do is add grease. This is what I've done for my locost.
All the above is for bolt on cvs but should be similar for push in.
Regards,
Mark
[Edited on 10/2/07 by dern]
R1 (2003 FI) powered Locost in progress
Fireblade/Impreza
nitram38
posted on 10/2/07 at 11:32 AM Reply With Quote
Talking of cv's, where can I buy new lobro joints 100mm with 86mm PCD ?
richard thomas
posted on 10/2/07 at 11:34 AM Reply With Quote
They are bolt on ones...
The reason i asked the question is that my local factors wanted about £130 each side..sure there must be a cheaper place??
dern
posted on 10/2/07 at 11:36 AM Reply With Quote
Try a different one. I think I got mine from partco.
Fireblade/Impreza
TimC
posted on 10/2/07 at 11:43 AM Reply With Quote
Rich
While I think about it, I've got a big tub of CV grease (actually unopened in my car at present) so don't buy it if you don't have to.
TC
RazMan
posted on 10/2/07 at 11:52 AM Reply With Quote
My local motor factor did them for under £20 inc vat - try and get the type with a metal/rubber composite cover as they are much better.
Raz
worX
posted on 10/2/07 at 12:02 PM Reply With Quote
driveshafts on ebay
http://cgi.ebay.co.uk/Driveshaft-Ford-Granada-Sierra-RH_W0QQitemZ160064501017QQihZ006QQcategoryZ21654QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
flak monkey
posted on 10/2/07 at 12:07 PM Reply With Quote
CV Joints are available from Hewitt Motorsport
http://www.hewittmotorsport.com/
Same as we use on our race car. Give him a call, very helpful chap
[Edited on 10/2/07 by flak monkey]
Sera
http://www.motosera.com
nitram38
posted on 10/2/07 at 12:09 PM Reply With Quote
Cheers !
richard thomas
posted on 10/2/07 at 12:14 PM Reply With Quote
Thanks,
Now for stupid question time....is there a difference between bolt on driveshaft types?? I have 4 driveshafts, 2 from an XR4x4 and 2 from a 2 ltr. they are both bolt on types (as opposed to push in) and i can't see any great difference between the two pairs, 100mm dia and 25 spline...i dont want to order the wrong ones. surely all bolt on type shaft are the same??
[Edited on 10/2/07 by richard thomas]
Catpuss
posted on 10/2/07 at 02:43 PM Reply With Quote
Halfords do, with trade card, about £65 for exchange units.
There was a thread about somehwhere in nottingham that do them for £50.
Macpa or whatever they are called in Leicester do about £68 for exhanges.
Chippy
posted on 10/2/07 at 06:01 PM Reply With Quote
Got mine from Camberly Auto Factors, about £20 IIRC definately not more. HTH Ray
