FlansS14
| posted on 20/2/07 at 02:02 PM |
Extending the colum
i need to extend my colum about 16"+ and then have the issue of a Alternator in the way. am i right in thinkin as long as there are no more
than 2 joints it will be fine.
anyony know the best place to soure the bits to do this.
Thank you all
Why didn't i just make it simple!
matt_claydon
| posted on 20/2/07 at 02:21 PM |
Have seen someone on here with about four or five joints in the column who isn't having any problems. Can't help with supplier though.
| posted on 20/2/07 at 03:29 PM |
Put a joint in the middle that clears the alternator and support it against a chassis member.
chockymonster
| posted on 20/2/07 at 03:41 PM |
Agriv8 has this pic in his archive.
  steering UJ
John Bonnett
| posted on 20/2/07 at 04:56 PM |
For the Phoenix, I am using a MK1 Sierra column which has a splined type uj. I purchased the extension rod which is splined at both ends from Dax (DJ
Sportscars)http://www.daxcars.co.uk/start.htm
The spline fits the Sierra uj and at the other end i fitted a second uj bought from Rally Design, http://www.raldes.co.uk/. I cut the splined rod in
the middle, shortened to suit and welded a sleeve over the joint. I put in a couple of rollpins for good measure.
I hope I have attached a picture and that this is of help to you.
John
FlansS14
| posted on 20/2/07 at 07:39 PM |
blimey..... Weld+spline+roll pins.. thats not going anywhere
how much was the rod if you don't mind me asking. Don't Dax get funny about parts if you don't have a DAX car... i remember someone
saying...
