Author: Subject: My unions won't but up.. anyone close to MK with some
FlansS14
posted on 24/2/07 at 07:08 PM Reply With Quote
Im desperat need of some m10x1 long unions like this
http://www.nfauto.co.uk/brake_flaring_tool.htm
mine are the brass ones and shorter. i have the 4way unit form car builders but when i flare the end and put it in the union is to short to lock the pipe up (if that makes sence) which is odd coz the rear 3way was fine with the shorter fittings.
anyone got any close to Milton keynes, i was hopein to get this done this weekend.
Thanks guys
Why didn't i just make it simple!
Avoneer
posted on 24/2/07 at 09:23 PM Reply With Quote
You can cut the brass union arms shorter.
Easy fix.
Otherwise, most motor factors will have longer unions.
Pat...
FlansS14
posted on 24/2/07 at 09:40 PM Reply With Quote
Pat...
good idea... i like that one
posted on 25/2/07 at 10:22 AM Reply With Quote
Sounds like your flares aren't big enough, the end of the pipe should stand very slightly proud of the die you flare it.
