| posted on 26/2/07 at 10:51 PM |
Please check ya nuts / a question I should have asked a long time ago
Holy moly that was one exciting blat! Unfortunately too exciting.......
How do you tighten up the nuts on the top and bottom of the upright? When I try to tighten them the bolty bit attached to the wishbone just swivels in
the upright? I seem to remember planning on torqueing them up fully once the car was on the floor and the weight was pushing the tapered thingy into
the bush. Guess I forgot!!!
Sorry if this makes no sense. I ask 'cos at rather high speed my bottom wishbone decided it no longer wanted to be attached to the upright.
Wishbone dug in like a byatch! Much sparkage... New trousers time.... Annoyingly (and rather amazingly) nothing snapped, I found the nut 100m back up
the road, and almost managed to get the wishbone thingy back into the upright bush with a large amount of brute force but the silly amount of preload
on the front shocks due the my protruding sump meant I couldn't... To make matters worse, the RAC man turned up with a trolley jack but no
spanners (and of course I didn't have a 18mm spanner in my collection)..... Ended up putting it on a flatback truck back to my garage after
ratchet-strapping the wishbones against each other....
Oh well, Dr Shakey Hand Man got to go and drink some scotch to calm the nerves....
greggors84
| posted on 26/2/07 at 10:57 PM |
When tightening the bottom ball joint, try jack it up from underneath the wishbone to push the taper right in the hole, not sure what you can do the
for the top one? Are they sierra uprights? One i had got mine in the mushroom inserts they tightened up fine.
RAC man had no spanners! I guess most modern cars on the road can't be fixed with simple spanners anymore!
Maybe join the AA, the man who turned up yesterday did a wonderful botch job on my HT lead!
Chris
The Magnificent 7!
graememk
| posted on 26/2/07 at 10:58 PM |
that happend to me on a pre sva shake down in b&q's car park
i was only doing 40 ish and i poo myself
| posted on 26/2/07 at 11:04 PM |
Yup- trousers and boxers in the wash
| posted on 26/2/07 at 11:05 PM |
I think what happened is when I made the car that's what I did but I put the chassis on very early so there was only 100kg(ish) pushing the
swivel into the bush.... 400kg later (pushing in the opposite direction) and the result was obvious....
wilkingj
| posted on 26/2/07 at 11:11 PM |
Daft question... You ARE using brand new Nyloc nuts?, or a castellated one with a split pin?
Nylocs should only ever be used once then thrown away.
Best Regards
Geoff
http://www.v8viento.co.uk
| posted on 26/2/07 at 11:18 PM |
Yup. New lower swivel with new nylock, only ever put on once!!! Might pin it next time!!!
greggors84
| posted on 26/2/07 at 11:44 PM |
I had a new nyloc mysteriously come off an engine mount. SVA tester spotted it first. Luckily he 'found' one in the car.
[Edited on 26/2/2007 by greggors84]
Chris
The Magnificent 7!
bartonp
| posted on 27/2/07 at 09:05 AM |
You might try some studlock on the taper (NOT threadlock)
| posted on 27/2/07 at 11:06 AM |
Mine did that once as well !
Dog it up with a plain nut first to lock it in the taper then put the nyloc on and tighten it again. It spins when the lock part catches on the end
thread. Mine had stripped the thread so it wouldn't go back on and I had to leave it overnight on someone's drive. It threw it down
overnight and I had to bail it out when I went back with a new joint. The wishbone was saved by the nuts holding the balljoint hitting the road first
and grinding down to about half height.
daviep
| posted on 27/2/07 at 12:44 PM |
Why would you put "studlock" or any other type of retainer on to the taper?
As suggested if you cannot stop the taper turning when putting a nyloc nut on use a plain nut first to seat the taper and then remove it and fit the
nyloc and torque it to the correct value.
The two mating faces of the taper should be spotlessly clean and free of oil or grease before fitting. Bolts and studs which are in good condition and
torqued to the correct value will not come slack.
NS Dev
| posted on 27/2/07 at 01:15 PM |
Had the same happen to me driving someone elses Westfield!
Unless I know them I spanner check first now!!!!
Mine was at low speed, and managed to fix it enough to limp back to the garage using a fence post, pliers and scissor jack from a nearby house.
| posted on 27/2/07 at 06:43 PM |
Yup. Bolts to tighten first sounds a proper job... I was wondering about the studlock....
les
posted on 6/3/07 at 07:58 PM |
jeez!
I was worried about this on mine even before i read that lot!
i only have about 1 turn of thread if that poking out past the nut(tiger avon, cortin a upright)
tiger say this is fine- i dont habve enout thread to drill through and pin it.
the avon book states that you should drill through the whole nut and thread then pin it, anyone think this is a good idea ? / any thoughts?
les
| posted on 6/3/07 at 09:32 PM |
It's fine, lots of people have passed SVA with nuts locked like this.
| posted on 6/3/07 at 10:24 PM |
What sort of torque are we talking about on the nut?
I've tightned mine up to 50lbf so far and intend to put some penetrating loctite on it .
