Author: Subject: steering extension
gy351100
posted on 1/3/07 at 10:42 PM Reply With Quote
steering extension
hi
can anyone tell me where i can get the uj clamp for the bottom of a sierra column and also extension bar and uj's to fit escort rack
cheers
keith
[Edited on 1/3/07 by gy351100]
mistergrumpy
posted on 1/3/07 at 10:47 PM Reply With Quote
rally design
locost parts
You can knock the extension up yourself, if you can weld or get someone to do it for you and just get the lower steering column which includes the uj's and clamp from a local scrappy.
posted on 2/3/07 at 07:15 AM Reply With Quote
Make sure you pin the parts together when welding your own.
You don't want it coming apart in the tight bend with the back end out....
twybrow
posted on 5/3/07 at 05:42 PM Reply With Quote
Does the Capri steering extension fit the bill? i need one to go from Sierra column to escort rack... It has a rubber end and a small U/J... Is this a standard Ford size?
twybrow
posted on 7/3/07 at 05:05 PM Reply With Quote
Anyone know? Come on, someone must know all about Ford parts!?
flak monkey
posted on 7/3/07 at 05:08 PM Reply With Quote
Theres plenty of threads on this if you used the search function.
All the manual ford steering racks are the same splines. Anything which had PAS had bigger spines.
You can just use a downlink from a sierra and chop and extend it.
Sera
http://www.motosera.com
twybrow
posted on 8/3/07 at 08:17 AM Reply With Quote
Thanks Flat Monkey. I had tried several searches, but no definite answer. Sorry for any inconvenience caused and thanks for your response.
