Author: Subject: Diff numbers identification
bug1
posted on 3/3/07 at 09:56 AM Reply With Quote
Hi can anybody help me ident my diff I carn't find the numbers on my list they are V85BB 006AA 4A 3.62 6G08 I know the ratio is 3.62 and I think it's a limited slip diff am I correct ?
fatfranky
posted on 3/3/07 at 10:07 AM Reply With Quote
Can't help with the numbers, doubtless someone else can soon, but here's how i check.
Try turning driveshaft output flanges in opposite directions, if they are difficult to turn then it's LSD, if they turn easy it's conventional diff.
To check ratio, put 3 tippex marks on all 3 flanges, turn driveshaft flanges in the SAME direction and count the turns until the propshaft mark comes back to it's original mark, 3.5 turns is easy to count and you should be able to guess near enough the remaining 0.12.
If you want to be REALLY sure, keep going until the propshaft flange has gone 10 revolutions, and driveshaft turns will be 31.4, 33.8, 36.2 or 39.2 turns respectively
Hope this helps
EDIT Why do I only spot my spelling mistakes AFTER i've posted
[Edited on 3/3/07 by fatfranky]
markal
posted on 3/3/07 at 10:21 AM Reply With Quote
Any number with A A in is a LSD, regards Alan.
[Edited on 3/3/07 by markal]
bug1
posted on 3/3/07 at 02:02 PM Reply With Quote
Thanks it looks as if it definately lsd
