Author: Subject: ADVICE - ALLOY GRADE
muzchap
posted on 24/3/07 at 06:07 PM Reply With Quote
I'm looking to make an adaptor for some brake calipers.
I'm running standard Sierra hubs and have some nice little two-pot calipers to put on.
I know Willwood etc make these adapators - but what grade Alloy should I use?
I have access to CNC machines etc.
Regards,
Murray
If you believe you're not crazy, whilst everybody is telling you, you are - then they are definitely wrong!
posted on 24/3/07 at 09:56 PM Reply With Quote
I would use steel instead of ali. They will be quite small so no punish for the heavier steel bracket.
Nick Skidmore
posted on 24/3/07 at 10:29 PM Reply With Quote
6082T6 which is HE30 or 2014AT6 which is HE15TF if you can get it
flak monkey
posted on 24/3/07 at 11:54 PM Reply With Quote
Two of the strongest ali alloys are 2014T6 and 7075T6. Both of which are stronger than mild steel, but neither are weldable.
Sera
http://www.motosera.com
muzchap
posted on 25/3/07 at 07:42 PM Reply With Quote
Thanks guys
New people on here would be able to help
Hopefully, I wont need to weld it - I might make the template in a lesser quality alloy that can be welded (helps rectify mistakes quickly) and then once I have a template make the finals in 'proper' grade
Thanks again to everybody that posted
Regards,
Murray
