Author: Subject: Bump steer - I Know!
mistergrumpy
posted on 25/3/07 at 03:11 PM Reply With Quote
Despite having read all previous threads, and I have read them all I've been at this for about half a day now and can't get it. There's obviously some black art to it and I can't figure what it is. These are my conclusions, however, please be patient here with me. Steering arms to be parallel to the wishbones, the pivot between the arms and the actual rack to be in the line of the upper and lower front wishbone pivot points.But, the rack and therefore distance between the two pivot points is 600mm and the only place their is 600mm between the two imaginary lines ( between the wishbone pivots) is just below the actual top bracket which therefore means the steering arms can't be parallel to the wishbones. I'm missing summat here aren't I? I can't go too low and far back either as my lower steering column fouls on the chassis, which I found out to my cost when trying to fit it Pished off with it now, gonna go and sulk in the corner
russbost
posted on 25/3/07 at 03:49 PM Reply With Quote
Suspension is always a compromise, unless you're planning a lot more travel than the average seven type vehicle you're unlikely to encounter much problem with bump steer (unless you're going to put the rack somewhere really peculiar)- I think it is something which tends to be somewhat exagerrated. If you're building a "seven style something" is there not a set design place for the rack or are you building your own one off design from scratch?
posted on 25/3/07 at 04:16 PM Reply With Quote
Agreed - I put no special effort into getting rid of bump steer, apart from getting the rack the right height.
There may be some bump steer, but it doesn't bother me at all.
ecosse
posted on 25/3/07 at 05:13 PM Reply With Quote
i have my rack fitted just below the top bone brackets and have mounted the steering arms above the hub arms rather than below using rosejoints instead of TRE's - result = practically no bumpsteer at all and thats through a range of movement greater than my shocks will allow, sorted
Alex
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 25/3/07 at 05:22 PM Reply With Quote
Bumpsteer
I disagree and feel it is worth the effort to get zero bumpsteer. Its one of the things that add up to a car feeling just right instead of OK. If you are positioning the components you may as well as position them in the place that will minimise bumpsteer.
I did the calculations as per the books etc but did not trust these to actually cut metal. So I made a model of my suspension, upright and proposed steering arms out of stiff card with pins on a board. Then I could move the suspension up and down and check that I had minimal bump steer.
Then once on the car I checked it and fine tuned by altering the height of the track rod end on the upright. It was worth the effort because a friend drove the car down a particular bad bit of road where they test Jags and Landrovers and proclaimed my car better.
mistergrumpy
posted on 25/3/07 at 05:23 PM Reply With Quote
Wahey, I've got it. I'm out for my tea now but I've found a computer just to show off. More luck than anything. Its only a few mm now, thats good enough for me. Cheers fellas
