Author: Subject: Master cylinder height
mistergrumpy
posted on 2/4/07 at 05:09 PM Reply With Quote
I thought that when mounting my master cylinder I had to have it so the level in the reservoir was higher than the calipers in order to maintain a head of pressure, but on looking through some pictures I see that some have it just above the floor pan height, an MK chassis it was. Am I wrong then?
stevec
posted on 2/4/07 at 05:11 PM Reply With Quote
It won't matter if it is lower, Mine is.
There is a pic here.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=P1010080.JPG
Steve.
[Edited on 2/4/07 by stevec]
mistergrumpy
posted on 2/4/07 at 05:17 PM Reply With Quote
Sorted. Thought it might cause air traps if it were lower. Cheers
RazMan
posted on 2/4/07 at 06:56 PM Reply With Quote
It is a commonly misunderstood thing. Gravity doesn't affect the braking system and it works solely on hydraulic pressure.
Raz
caber
posted on 2/4/07 at 07:43 PM Reply With Quote
Yes but air naturally heads for the highest point in the system, it can escape through the master cylinder but it cannot escape elsewhere so gives grief when bleeding particularly if the high point ends up being the top of the diff on a solid axle!
Caber
mistergrumpy
posted on 2/4/07 at 08:40 PM Reply With Quote
That was my concern Caber.
Raz, are you calling me common then
stevec
posted on 2/4/07 at 08:49 PM Reply With Quote
I bled mine on my own in no time.
Piece of piss,
You have to believe,
Steve.
mistergrumpy
posted on 2/4/07 at 08:56 PM Reply With Quote
I will/am. A picture can't lie. Cheers steve
posted on 3/4/07 at 11:29 AM Reply With Quote
Having the reservoir mountedhigh has an advantage in that a very slight positive head helps keep the rubber seals expanded and pushed into good contact against the cylinder bores.
