AdamR
| posted on 3/4/07 at 07:40 PM |
column bush - how big is it?
How big do I need to make the hole for my Sierra lower column bush?
I don't yet have one so cannot measure it, before you ask!
Ta
A
big_wasa
| posted on 3/4/07 at 08:26 PM |
The hole for my paten one is 42mm dia
AdamR
| posted on 3/4/07 at 09:23 PM |
Thanks.
Unfortunately 42mm seems to be the only size that you can't buy a holesaw in... Do you reckon a 44mm hole would do the trick? Anyone?
[Edited on 3/4/07 by AdamR]
mistergrumpy
| posted on 3/4/07 at 09:25 PM |
Dunno but I stitch drilled mine then filed it down. Takes a bit longer but satisfying when you've done it
Gav
| posted on 3/4/07 at 09:27 PM |
i used the next hole saw down then used a dremmel to take it out to the right size
big_wasa
| posted on 3/4/07 at 09:30 PM |
Chain drilled and filled mine. It needs to be a very snug fit or it will pull out and flop about.
May get away with a size smaller?
Best bet is get a bush and start from there.
mistergrumpy
| posted on 3/4/07 at 09:33 PM |
^£4 odd from Ford dealer in case anyone were gonna start paying E bay prices.
[Edited on 3/4/07 by mistergrumpy]
big_wasa
| posted on 3/4/07 at 09:43 PM |
Loads on e bay for around £4
This
one is £4 with postage
AdamR
| posted on 3/4/07 at 10:06 PM |
Cheers guys... I have a bush kit on order from MNR (also £4) along with some other stuff.
Think I'll buy a cheap holesaw set and use the 40mm + Dremmel as suggested.
Ta.
mistergrumpy
| posted on 3/4/07 at 10:14 PM |
Mines slightly under to be honest but is a nice snug fit without a kink mind. Good luck.
| posted on 4/4/07 at 10:52 AM |
Mines brand new and knocks like hell. Theres loads of clearance to the triangular shaft.
Theres a distinct knock when I turn the wheel that just wouldn't be accepted by Ford these days!
