Author: Subject: Vented disc question ?
big_wasa
posted on 7/4/07 at 08:25 PM Reply With Quote
Was telling some one about my hobby as you do He replied "back in a mo".
He came back with two new pairs of capri vented discs. Said I had new solid discs but insisted he was fed up of triping over them
Is the extra braking worth the £35 I would need to spend on the spacer kit ? along with the extra weight it would add.
[Edited on 7/4/07 by big_wasa]
gazza285
posted on 7/4/07 at 08:37 PM Reply With Quote
This is what eBay is for.
gazza285
posted on 7/4/07 at 08:40 PM Reply With Quote
There is no extra braking available, vented discs reduce the chance of brake fade due to overheating, however the low weight of a Seven rep means that overheating is much reduced anyway compared to the car that the brakes were originally designed for. Bling factor though....
posted on 7/4/07 at 08:45 PM Reply With Quote
on the balance i belive the extra weight makes them undesirable. Some even say you want hot discs so they radiate heat faster.
Dingz
posted on 7/4/07 at 10:10 PM Reply With Quote
Solid ones don't warp either
big_wasa
posted on 8/4/07 at 07:31 AM Reply With Quote
Cheers guys that sorts that
Edit....
turns out they are not 2.8 capri but more like 2.8 sierra/4x4/s2 Rs turbo
ie they are 260mm and bolt between wheel and hub.....
Any body looking for a new pair ?
[Edited on 8/4/07 by big_wasa]
wilkingj
posted on 8/4/07 at 10:19 AM Reply With Quote
They are good brakes. I just fitted some to my Viento.
Better than the 240mm ones I have fitted.
But then I have more weight in Me ... nad the Viento
Best Regards
Geoff
http://www.v8viento.co.uk
wilkingj
Best Regards
Geoff
