| posted on 8/4/07 at 04:37 PM |
what 13" wheels go over sierra rear discs?
as the title really, im trying to get wheels without having the rest of the stuff yet, would rather avoid trouble later. I want 13s so i can use cheap
slicks. Ta!
| posted on 8/4/07 at 04:49 PM |
en excellent point john, but im on a deadline now so need quick simple solutions for now. If i had time it would get a pair of bike discs and calipers
but then id need to lathe bells up (in fact id have to learn to use a lathe too ) so for now i just want to chuck on standard parts
chockymonster
| posted on 8/4/07 at 05:22 PM |
Caterham 8 spoke 6x13" wheels fit over sierra calipers.
The minators don't
mark chandler
| posted on 8/4/07 at 05:23 PM |
I,ve got proper minilights on mine and had to modify the calipers (came off a caterham, even then two fit (slightly sanded finish on the inside) and
two do not (machined finish). All wheels have the same numbers.... cannot explain that but got off Ebay as a set.
In hindsite I should have modded the brackets to bring the caliper in slightly to have avoided doing this, ie welded the holes and redrilled closer
the hub.
I tried revolution wheels (retro ford) and these did not come close.
Regards Mark
[Edited on 8/4/07 by mark chandler]
matt_gsxr
| posted on 8/4/07 at 07:19 PM |
13x6J Compomotive revolution 4-spokes don't fit.
You can get them to fit by either spacing (about 20mm), or doing all of the popular trimming tricks (i.e. moving holes, angle grinder to back of
calipers, angle grinder to pad backing, angle grinder to tweak the inside of calipers). I am told that Escort MkIII (I think) front disks, and moving
the holes for the caliper mount is an easier option (as you can ignore the angle grinding, all parts are stock, and the cost is low) but I found out
too late.
Matt
| posted on 8/4/07 at 07:35 PM |
IIRC, 13" Compomotive CXR's will fit over standard Sierra rear discs and calipers. They're not cheap though.....
Phil
Minicooper
| posted on 8/4/07 at 08:02 PM |
Hello Joel,
This is standard sierra everything on the back of my mini, I bought them of you! anyway they are fitted under a 6*13 KN Minators, et I think is 5 or 6
mm bought from MWS ltd.
I fitted 6mm hub centric spacers, not for the diameter but for the handbrake hook bit to clear the inside lip, though some people bend the hook down
to clear
bigrich
| posted on 8/4/07 at 11:34 PM |
cxr's definately fit seen them on a few kits with standard rear brake set ups. you just have to slightly tweak the spring on the caliper h/b
release mechanism
| posted on 9/4/07 at 01:47 AM |
its all too complex i just want a cheap way to get the car moving! Either 13s with slicks, 13s with r888 or 14s with r888. In the long run i want
slicks, so i need to pick a second hand 13 that will fit. Maybe i should just research the mods required to get any wheel on. Cheers for the help so
far!
| posted on 9/4/07 at 12:38 PM |
some pondering and i have concluded i might be best using rear drums for now, as this would mean i can use a single master cylinder and still have ok
brake balance, plus its lighter, and then i can swap for bike discs and calipers at a later date. Also means i can get some cheap ass 13s and slicks
off ebay, for less than £100 all in!
How does this sound to anyone? Cheers!
| posted on 9/4/07 at 05:16 PM |
quite true john, however if a normal disc provides too much braking, why not use a pair of 50cc moped discs and callipers?! That must be lighter
kastrato
| posted on 9/4/07 at 07:33 PM |
stupid newby question here who might done something stupid again!!!
I bought these from ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=009&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=190096879012&rd=1&rd=1
I have sierra discs front and drums in the back.
Would these fit my car???
MK INDY fireblade
