graememk
| posted on 23/4/07 at 09:31 AM |
i have another nut and what size situation
sierra front uprights behind the dust cap is a big nut thats loose and needs to be tighter, what size is it, looks like a 41mm with my measure so i
assume its not quite accurate
anyone know the size before i go out and buy 10 sockets untill i find one that fits
many thanks
COREdevelopments
| posted on 23/4/07 at 10:55 AM |
yes 41mm will fit as i done mine with one a few weeks ago.
graememk
| posted on 23/4/07 at 10:59 AM |
what an odd size
Mr Whippy
| posted on 23/4/07 at 11:18 AM |
I'm a bit concerned that it's came lose, I think I would replace the nut as there's no other locking device and you don't want
the wheel coming off.
Are you sure the hub is on the correct side??
graememk
| posted on 23/4/07 at 11:24 AM |
i bought them all recon, i think it just wasnt tight enough. they look like new still
James
| posted on 23/4/07 at 02:13 PM |
quote: Originally posted by graememk
what an odd size
Same as the Sierra rear hub nut size.
- Muhammad Ali
flak monkey
| posted on 23/4/07 at 02:34 PM |
Probably originally 1 5/8" nuts (0.27mm bigger across flats)
41mm sockets are easily had though.
Sera
http://www.motosera.com
gazza285
| posted on 23/4/07 at 03:00 PM |
41mm is the ISO standard across flat size for 27mm threaded nuts.
bodger
| posted on 23/4/07 at 03:02 PM |
Make sure it's tight 3501bs/ft according to the Haynes manual, got the local garage to torque mine up; as Mr Whippy says, you don't want
