Author: Subject: de dion tube
oadamo
posted on 1/5/07 at 08:44 PM Reply With Quote
de dion tube
hi ive started making the parts for a de dion tube but do people build them with any camber into them.
posted on 1/5/07 at 08:46 PM Reply With Quote
can do, or you can shim it later to adjust angles - also useful if it distorts.
oadamo
posted on 1/5/07 at 08:57 PM Reply With Quote
ive only cut the shape out of one side with a flat on the other if you no what i mean. so i can use the flats to get it level i hope. how much shim would you need for what amount of camber. because k ford tyres by me has a full lazer setup thing that can do camber/ toe in/toe out he said £50 for a full setup so i could take a load of shims with me when its done.do you make them 1mm or 1/2 mm and just keep adding them cus if you put a spacer at the bottom there wont be much contact with the hub or doesnt it matter
adam
givemethebighammer
posted on 1/5/07 at 09:02 PM Reply With Quote
The shims required to adjust the camber and toe on sierra hub carriers are tiny. See the attached spreadsheet. Small adjustments at the hub carrier make big adjustments at the wheel rim.
oadamo
posted on 1/5/07 at 09:07 PM Reply With Quote
oh i dont have spreadsheet at home on my laptop
givemethebighammer
posted on 1/5/07 at 09:11 PM Reply With Quote
Open office calc will open it and it's free !
http://www.openoffice.org/
oadamo
posted on 1/5/07 at 09:25 PM Reply With Quote
sorted thanks it doest look like ill be making loads of 1mm shims then lol
anyone no what camber to start with.
the cars only gonna be used on the track and the odd blast on the road
adam
craig1410
posted on 1/5/07 at 10:29 PM Reply With Quote
I built mine with a little bit of camber and a little bit of toe-in. My thinking was along the lines of - I can't expect 100% accuracy and I'd rather err on the negative camber/toe-in side than on the positive camber/toe-out side.
I worked it out at the time (several years ago now) and I think I was aiming for something like 3mm static negative camber and 3mm of toe in (1.5mm each wheel). I worked out the spacers I needed just happened to be the thickness of some hacksaw blades I had lying around so I used them to hold the parts in place while I tack welded them.
I then assembled the axle temporarily and checked that I did indeed have negative camber and a bit of toe-in. To measure toe-in I just strapped a straight edge to the wheel and measured the gap between the straight edge and the chassis side rails. To measure the camber I just put the car on the ground and used a large framing square set against the rim.
I can fine tune it once it's on the road.
Craig.
posted on 2/5/07 at 07:51 AM Reply With Quote
When making a de Dion tube to set both the camber and toe-in all that is required is a level surface and a precision (or digital) spirit level.
craig1410
posted on 2/5/07 at 08:45 AM Reply With Quote
I think most Locost builders are more likely to have copious quantities of old hacksaw blades myself....
oadamo
posted on 2/5/07 at 05:53 PM Reply With Quote
iam not far off finishing it hes a pic of the caliper brackets ive gotta file the inside but i think they turned out well ive just gotta weld the tube to join the hub brackets together
adam
posted on 2/5/07 at 07:36 PM Reply With Quote
excellent work there adam, must've taken ages chain drilling the big hole!
ah you used a plasma didnt you
[Edited on 2/5/07 by JoelP]
oadamo
posted on 2/5/07 at 08:05 PM Reply With Quote
i didnt have anything the right size to cut around for the big hole so i have to move a washer around a bit at a time and use that lol
adam
oadamo
posted on 3/5/07 at 05:34 PM Reply With Quote
well fek me i just went to try them on the hubs then i realised that the hubs where off a 4x4 and have the caliper fitting on them lol. i looked at the drawing and just started making them without thinking lol.
anyone want them u2u me ill post them for free as i have no need ive checked them and they do fit but iam not fileing them lol you can but they fit anyway
adam
i no iam a tit
