Author: Subject: 5 to 4 stud fitting.
goodguydrew
posted on 4/5/07 at 11:13 PM Reply With Quote
Hi all,
is there an adaptor available to let me use ford 5 stud wheels on a 4 stud escort axle? Thanks
RazMan
posted on 4/5/07 at 11:15 PM Reply With Quote
There are a few spacer/adaptor thingies on eBay I think.
Raz
goodguydrew
posted on 4/5/07 at 11:19 PM Reply With Quote
Hay, Raz, I saw your car in the magazine. Well done.
I'll give ebay a try. Thanks.
[Edited on 4/5/07 by goodguydrew]
RazMan
posted on 4/5/07 at 11:26 PM Reply With Quote
Thanks Drew - it will be at Stoneleigh on Sunday too
I was looking at spacers last week and found some converters in one of the eBay shops ............. can't find it now
Raz
jollygreengiant
posted on 5/5/07 at 08:26 AM Reply With Quote
Originally posted by goodguydrew
Hi all,
If you are using sierra IRS with bolt on drive shafts, then the rears are simple, just change the outer drive plates to Granada ones. If you are useing sierra front uprights then get Granada spindles turned down to fit.
Hammerhead
posted on 5/5/07 at 09:46 AM Reply With Quote
you need hubcentric adaptors, I had some machined up because the pcd was not a std one. You may be lucky and find some available off the shelf.
