Author: Subject: cortina mk 3/4 brake seals
posted on 8/5/07 at 09:07 AM Reply With Quote
From where can I get brake seals for cortina mk 3/4 claipers?
I think these are M16 that as I understand it were fited to a variety of crotinas but if I wer to go to Ford/Motor factors, they ask for car year/model etc. which I don't know
It looks like one of the pistons is seized - is it possible ot push irt out with caliper still fitted and clean it up or is it new seals time?
Failing that, I see RD do lost of calipers - any one know which model would be a direct replacement? (have sierra master with 8 inch mk2 escort drums)
TGR-ECOSSE
posted on 8/5/07 at 09:27 AM Reply With Quote
Try typing cortina calipers in ebay there are always a few seal kits there. I got the same questions about year etc at motor factors and asked them to check part numbers and guess what? MK3,4,5 cortina were all the same.
Linky to caliper stuff supplier
[Edited on 8/5/07 by TGR-ECOSSE]
Schrodinger
posted on 8/5/07 at 09:47 AM Reply With Quote
If the piston is siezed I would suggest it's time for a reconditioned caliper
DavidM
posted on 8/5/07 at 11:14 AM Reply With Quote
Calipers for Mk3/4/5 Cortinas were all the same so you shouldn't need the year. Just ask for M16's for a Cortina at your local motor factor. The calipers are readily available as they are also commonly used in industrial applications. Exchange reconditioned should only be about £60-70 for the pair.
If you need seals I think I've got a set I could let you have for £5. U2U if interested.
Mal
posted on 8/5/07 at 01:11 PM Reply With Quote
Caliper Seals
David,
If 02GF7 does not want your seals I will buy them from you.
Regards,
Mal
posted on 8/5/07 at 03:56 PM Reply With Quote
Originally posted by Mal
David,
Regards,
Mal
hahaha ... too late, I think. If for some reason they don;lt fit or I go for recon callpers, your name will be next on the list.
