mistergrumpy
| posted on 8/5/07 at 08:18 PM |
Brake Stop
I,m after a way to stop my brake pedal falling forward.At the moment I,ve just welded a bit of steel onto the end of the mounting bracket and ground a
groove onto it but I'm not happy with that,looks real crappy. Just wondered what anyone has done? I was thinking of putting a nut on the pushrod
and trapping it in the M.C. via summat like the steel cap that generally goes on the end of the M.C.
flak monkey
| posted on 8/5/07 at 08:20 PM |
I welded a little tab to the bearing/bush housing and put a bolt through it vertically that just rests on the floor. Lets you adjust how far back the
pedal lies.
Not a great explaination, but dont have a pic i am afraid.
Sera
http://www.motosera.com
mistergrumpy
| posted on 8/5/07 at 08:35 PM |
Ah. No I get it and I like it too.Have you put any kind of return spring on?
flak monkey
| posted on 8/5/07 at 08:38 PM |
No return spring, m/c seems to do a fine job. Though you could put one on between the clevis and the m/c body if you wanted to.
Sera
mistergrumpy
| posted on 8/5/07 at 08:39 PM |
Cheers mate. Top, simple idea. Love it, ta.
DIY Si
Mine's like that, just an L shaped bit on a lock nut on the pedal bolt. The pedal drops onto it and is adjustable to take the play out should
you wish. Really simple too, but not the most elegant solution perhaps.
Sun Tzu, The Art of War
| posted on 8/5/07 at 11:06 PM |
I used the return spring that came with the Escort pedals and welded a stop for it to pull the pedal onto, Ford thought it needed one.
  Top mount pedals.
C10CoryM
| posted on 9/5/07 at 01:14 AM |
If you can, put a return spring on. If you have a hydraulic failure or boil your fluid, your pedal will stay at the floor. Not good.
"Our watchword evermore shall be: The Maple Leaf Forever!"
Avoneer
| posted on 9/5/07 at 06:42 AM |
Neither will a hydraulic failure !
Pat...
