supercat
| posted on 12/5/07 at 07:06 PM |
Cortina Hub Assembly
Hi chaps,
I'm assembling my cortina hubs and wondered if anyone had the haynes manual handy, I need to know how tight to torque the bolts that hold on the
brake disc and also the main hub nut?
Cheers, James
Mal
| posted on 12/5/07 at 07:30 PM |
Torques
Disc to hub: 41 to 47 Nm.
Caliper to upright: 62 to 69 Nm.
If you are referring to the nut on the end of the stub axle, this is not torqued as the other two are, it is carefully adjusted to just absorb any
rock in the wheel bearings, without preloading them, and then the nut is retained by the serrated washed and held with a split pin,
HTH
Mal
big_wasa
| posted on 12/5/07 at 07:35 PM |
For the hub nut the book says torque to 27lb ft then undo by 1/4 turn.
[Edited on 12/5/07 by big_wasa]
Deckman001
| posted on 12/5/07 at 08:08 PM |
Finally getting to fit them eh
Jason
supercat
| posted on 13/5/07 at 08:44 AM |
Jason
A bit later than I thought but yes
Thanks for the replies.
