bodger
| posted on 24/5/07 at 08:19 AM |
Sierra rear pads
I'm hoping to put Mintex 144 or Ferodo DS pads on the front of my R1 Indy but is it worth upgrading the rear pads too or just stick to standard
Motor Factor pads?
worX
| posted on 24/5/07 at 09:12 AM |
If I were you - I'd put the standard cheapo ones if it's for the back.
But thats just me, I'm sure others would do different?
takumi
| posted on 24/5/07 at 09:13 AM |
rear pados
Ive got a set of calipers for my rear end, I'm going to use std OE pads and maybe drilled discs.
Maybe slightly uprated pads with drilled sollid discs on the front.
nb: The brakes dont have to stop a heavy car, even on a std sierra, the brakes will lock the wheels at speed..
tk
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special
valves FR22 cam, 4- 1 header.
