Author: Subject: Type 9 to 4AGE
rusty
posted on 11/6/07 at 01:54 PM Reply With Quote
Type 9 to 4AGE
I am concerned about the Type 9 input shaft flapping around in the 4AGE crank, I think this may be what killed my last Type 9.
Does anyone think this is a problem, if so I was thinking of getting a bronze bush made to help locat the Type 9 shalft
stevec
posted on 11/6/07 at 02:00 PM Reply With Quote
The front of the spigot shaft must be supported by a bush or a bearing or when you depress the clutch you are putting strain on the gearbox input shaft bearing,
Steve.
R1 STRIKER
posted on 11/6/07 at 02:27 PM Reply With Quote
You can get the bearing you need from RAW engineering.
Ben.
rusty
posted on 11/6/07 at 03:57 PM Reply With Quote
Thanks for all the advice will get one for when the new box is fitted.
