Author: Subject: Back axle noise??
mad dad
posted on 19/6/07 at 07:14 PM Reply With Quote
Back axle noise??
When i am driving and lift off or am in traffic on a light throttle there is quite a bit of drive train noise from the rear but under load accelerating everything is fine could this be the back axle or is it normal?? Thanks
Wadders
posted on 19/6/07 at 07:23 PM Reply With Quote
Pretty much the norm in a bec, no need to worry
Al.
Danozeman
posted on 19/6/07 at 07:46 PM Reply With Quote
I wouldnt worry about it mate.
Dan
mad dad
posted on 19/6/07 at 09:07 PM Reply With Quote
Thanks for comments.......had a great drive tonight till i ran out of petrol!!!!!!!must get the fuel gauge wired up
Avoneer
posted on 20/6/07 at 06:23 AM Reply With Quote
Just double check your prop shaft bolts at the back.
Indykid though his was backlash and when checked, all four were loose.
Pat...
mad dad
posted on 20/6/07 at 11:31 AM Reply With Quote
Cheers Pat should be an obvious check but not done it yet so will get on it Friday when i'm back home Thanks......Andy
