Author: Subject: Solid Vs Vented on a BEC
Davey D
posted on 23/6/07 at 10:50 AM Reply With Quote
Im looking at building a Hayabusa engined car, and im pricing up parts at the moment.
I have seen the Raceleda & wilwood kits, but i see they are solid discs. what are these like for cooling? do they overheat and warp, or are they easily upto the job? im aiming to use the car on track quite a bit, so i want something that will stand upto the job
Wadders
posted on 23/6/07 at 10:59 AM Reply With Quote
Easily up to it IMHO, infact i reckon you could get away with thinner solid discs with no problems.
Al.
posted on 23/6/07 at 11:02 AM Reply With Quote
On a lightweight car like a 7 solid discs are fine. On a superlightweight car like a BEC seven they're definately up to the job....
scotlad
Contributor
Posts 781
Registered 30/9/03
Location Edinburgh
Member Is Offline
Photo Archive Go!
Building: Built MK Indy Blade, RH 2b Zetec, rebuilding locos
posted on 23/6/07 at 11:09 AM Reply With Quote
I seem to recall solid discs are lighter than vented ones too
Wonderous is our great blue ship that sails around the mighty sun, and joy to everyone that rides along!
worX
posted on 23/6/07 at 11:16 AM Reply With Quote
I'll second the above (or third/fourth it!)
You can even get away with running thinner solid disks as someone else has mentioned!
RazMan
posted on 23/6/07 at 11:35 AM Reply With Quote
You will probably find that you won't even warm up the vented disc enough and as a result braking efficiency will be worse than solids anyway.
Raz
bigrich
posted on 23/6/07 at 04:09 PM Reply With Quote
i used vented discs on my blade car and as said they are complete overkill in a 500 kg car and wiegh too much.. go with the solids they will be fine
ChrisGamlin
posted on 24/6/07 at 03:13 PM Reply With Quote
Yep, I originally bought a Wilwood kit with vented discs on my BEC but after a while I changed to solid discs for several reasons, weight, to improve warmup of the brakes as I had a hunch they were staying too cool, and also so I could fit the pads I wanted without having to grind them down and waste half of the pad material, because I couldnt get caliper spacers big enough to accomodate the vented discs and the thicker pads.
[Edited on 24/6/07 by ChrisGamlin]
NS Dev
posted on 25/6/07 at 04:14 PM Reply With Quote
Agreed, but!................................
it does depend on how you drive and on what roads.
I recently took my (200hp, car engined, 550kg) locost at a smartish pace down a road near to me which is all 150 to 300 yard straights followed by 90 degree bends, and the (mintex 1144) pads in raceleda 4 pot calipers over solid cortina discs had cried enough by the last corner, and pad fade was setting in as was a huge cloud of smoke.
However, that was pressing on, and not a normal driving situation, and by comparison my sierra 4x4 has no brakes whatsoever left by the last corner on that same road, while going MUCH slower between corners.
In the locost it tends to be braking from 90 to 40 ish for each corner.
Just to give you some idea. I am certainly not planning on changing my setup but it is fallible given the most arduous of tests, which isn't necessarily the track as you get more cooling between corners on the track.
