Author: Subject: Oil in CV joint
40inches
posted on 2/7/07 at 12:09 PM Reply With Quote
Oil in CV joint
Got a couple of drive shafts(push in) from a '86 Sierra 2litre, when I pulled back CV boot, oil poured onto workbench so I got another pair from a '89 diesel. They are oil filled as well. Did Ford use EP oil instead of grease on some year models or have I just been unlucky? twice! Would CV joints be OK running in EP oil instead of grease?
stevec
posted on 2/7/07 at 12:38 PM Reply With Quote
I have seen the grease in these joints turn to liquid but have never seen an oil filled one.
Steve.
iank
posted on 2/7/07 at 12:42 PM Reply With Quote
The grease in the mini CV's I got poured out as a thick black liquid. Horrible stuff to clean up as well
Anonymous
worX
posted on 2/7/07 at 01:39 PM Reply With Quote
I'm pretty sure it won't be oil, but the grease thinned out so much.
Just check everything as you would normally and then refit with new covers and grease as normal - "sould" be OK!
40inches
posted on 2/7/07 at 02:41 PM Reply With Quote
Thanks for that, looks and smells like EP90, as said, new boots and regrease I think
