Author: Subject: p100 pickup axle
oadamo
posted on 7/7/07 at 10:46 AM Reply With Quote
p100 pickup axle
hi at a scrapyard by me theres a p100 pickup with a good axle and prop would this be any good for a locost.
adam
mookaloid
posted on 7/7/07 at 11:16 AM Reply With Quote
Not sure the stud pattern will be ok - I think they are 5 stud.
The width may be an issue - you need to measure it
The ratio might be quite good if you are putting a car engine in - commercial vehicles tend to have a low ratio which will give quicker acceleration.
mark
gazza285
posted on 7/7/07 at 01:24 PM Reply With Quote
Trouble with the P100 is the weight as the walls are very thick, it will work, but there are much better alternatives.
delboy
posted on 7/7/07 at 08:27 PM Reply With Quote
definately a 5 stud wheel required, kind of limits things a lot if your using cortina or sierra front hubs.
