Author: Subject: bottom joints
joolsmi16
posted on 20/7/07 at 05:02 PM Reply With Quote
bottom joints
hi all, is there any track width differences between the cortina and maxi bottom ball joints?
As with the cortina joint the bottom wishbone is angled up to match the joint can the maxi ball joint be bolted on a flat surface? would this make it very slightly longer in track width.
flange nut
posted on 20/7/07 at 06:13 PM Reply With Quote
The simple answer is, no. It all depends on how you design the wishbones.
