oadamo
| posted on 22/7/07 at 10:40 AM |
drilling wheel hubs
hi i have some sierra rear hubs with the studs sticking out. could you redrill them to take wheel bolts.
adam
| posted on 22/7/07 at 10:47 AM |
Yes, but you'd need to be very accurate when drilling and tapping. You'd also need to check that the hub flange is thick enough to
provide enough thread depth/strength for the bolts.
If it's the length of the studs that's a problem you can get longer ones to press into the existing holes.
oadamo
| posted on 22/7/07 at 10:53 AM |
hi yes the studs are to short and i was thinking of turning the hub a few degees and redrill it.
adam
blakep82
| posted on 22/7/07 at 11:04 AM |
I'd just go for longer studs. but i've never liked bolts anyway
________________________
