Author: Subject: p clips
welshboy
posted on 25/7/07 at 03:35 PM Reply With Quote
p clips
hi all what sort of p clip do i need to pass the sva around the copper brake pipes will nylon do or do i need rubber lined thanks
worX
posted on 25/7/07 at 03:37 PM Reply With Quote
nylon is fine...
RazMan
posted on 25/7/07 at 03:38 PM Reply With Quote
Either will do but I would go for rubber lined if you can.
Raz
designer
posted on 25/7/07 at 03:53 PM Reply With Quote
Metal lined with rubber are the best choice for hard lines.
iank
posted on 25/7/07 at 03:59 PM Reply With Quote
Proper brake clips are best if you can get them, followed by rubber lined metal p-clips followed by nylon p-clips.
Anonymous
welshboy
posted on 25/7/07 at 04:25 PM Reply With Quote
thanks very much everyone for your help rubber lined it is then
Catpuss
posted on 25/7/07 at 05:06 PM Reply With Quote
I've used nylon ones at half the minimum interval, but then its a couple of quid a bag compared to a 25p to 50p each for the metal ones.
james h
posted on 25/7/07 at 05:18 PM Reply With Quote
I have used some clips from Demon Tweeks, two part plastic things which are pushed into a 6mm hole, then the line pushed inyo them.
Perfect for the job, and very secure
James
graememk
posted on 25/7/07 at 09:23 PM Reply With Quote
i used nylon but every 4-5"
