paulmw
| posted on 1/8/07 at 07:16 PM |
bloody caliper
I can't get the rear Sierra caliper to fit over the discs when the pads are in place
Ive read that you need to back the caliper off by turning it clockwise with needle nose pliers.
I must have turned it about 50 times and it hasn't moved - any suggestions?
Paul
jollygreengiant
| posted on 1/8/07 at 07:19 PM |
You need to turn the piston AND apply a constant push against the piston at the same time.
Chippy
| posted on 1/8/07 at 07:23 PM |
Agree with ^^^^ just get a G clamp that will compress the piston and then turn a bit, tighten the G clamp and turn again, etc, etc, etc, takes less
time than it takes to tell. HTH Ray
paulmw
| posted on 1/8/07 at 07:26 PM |
Oh right, cheers fellas.
Ive spent the last hour turning it
Back to the garage then
adithorp
| posted on 1/8/07 at 07:39 PM |
When you've got it back together, DON'T pull the hand brake untill you've pumped the piston out with the pedal!
Adrian
locoboy
| posted on 2/8/07 at 08:14 AM |
Sheet..........
I did this, what do i need to do to get back to square one?
Wind them in and use foot brake pressure to push them out?
Why should you NOT use the handbrake before pumping them out with the foot brake?
Locoboy
adithorp
| posted on 2/8/07 at 08:30 PM |
If you pull the hand brake without pumping the pads out then the lever over-throws and the adjuster disconects internally and no longer works!
Wind it back and try again,you could be lucky and get away with it but it may be fubah! Sorry.
Adrian
