The Doc
| posted on 2/8/07 at 06:38 PM |
Sierra Steering lock
My Sierra column does not lock. Were they all fitted with steering lock? If so what's likely to be wrong here?
TA
| posted on 2/8/07 at 07:03 PM |
Could be the barrel sticking not allowing the plunger to come forward and engage the lock.
If you need a new barrel the CD132 (2000~2007) Mondeo one fits. Get one from the scrap yard.
tks
| posted on 2/8/07 at 07:25 PM |
JUST IN CASE
useless to add that it locks on the steeringwheel sow without steeringwheel no luck is noticed..
Tks
| posted on 2/8/07 at 08:06 PM |
If you have changed the steering wheel you may not be able to lock steering.
| posted on 2/8/07 at 09:15 PM |
Steering wheels have nothing to do with the lock.....
indykid
| posted on 2/8/07 at 10:15 PM |
erm....yes they do. they have everything to do with it.
the lock works by engaging a steel bit in the back of the steering wheel. most aftermarket bosses don't have a high enough quality of casting to
give it anything to engage on, so if you've gone away from a standard steering wheel..........
tom
The Doc
| posted on 2/8/07 at 10:26 PM |
OK It's not an original wheel, so given that I have an key ignition do I need any more security for SVA?
TA
| posted on 3/8/07 at 10:13 AM |
Ah, sorry, i was in Mondeo mood.. The bolt engages a lock coller on the shaft rather than the back off the wheel.
You learn something new every day
