Author: Subject: Handbrake
caber
posted on 5/8/07 at 10:15 PM Reply With Quote
Handbrake
I thought I would be clever and use a Lotus Elan umbrella handle hand brake. I have a Capri axle and standard drums and have made a contraption to provide leverage between the handbrake lever and the brakes. At the moment i can't get the handbrake to bite. I don't have hydraulics working so do I need this to get the drums to self adjust or is there something else needing fixed?
Caber
Chippy
posted on 5/8/07 at 10:30 PM Reply With Quote
Pretty sure that you have to pump the brakes, on the pedal, to close up the hand brake adjustment. I have heard that if you use the hand brake prior to doing this you can screw out the threaded section in the calliper, meaning a strip down to put it back, (don't know if that is true though). Regards Ray
indykid
posted on 5/8/07 at 10:54 PM Reply With Quote
with drums?
if the adjuster in the drums is set right, i'd assume the handbrake should work without any fluids.
what's this 'contraption'? do you actually end up with any leverage by the time you get to the drums?
pics or a nice drawing might help
tom
Chippy
posted on 6/8/07 at 09:57 PM Reply With Quote
Whoops, my mistake, didn't read the drums bit. Grovel, grovel, Ray
