Author: Subject: Rear hub assembly
madrallysport
posted on 8/8/07 at 09:12 PM Reply With Quote
Rear hub assembly
Hello All
I'm after a few pictures of a complete rear hub assembly using disk brakes etc, I am looking to see were you all have placed your calipers etc (ie at the front of the rear wheel or at the rear)
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
james h
posted on 8/8/07 at 09:16 PM Reply With Quote
the mk's is towards the rear, approximately 35-40 degrees from the vertical (i think, I am sure someone will correct me)
However, in the build manual the calipers need to be bled when off the hubs
Hope this helps
mark chandler
posted on 8/8/07 at 10:16 PM Reply With Quote
Calipers not hung on this but you can see the position of the bracket.
Just have to remove the caliper if bleeding the brakes. Rescued attachment NSR_suspension22Jan2005.JPG
RazMan
posted on 9/8/07 at 09:10 AM Reply With Quote
Calipers often get mounted upside down to make the handbrake cable route easier. It just means you have to remove them while bleeding the rear brakes.
Raz
