Author: Subject: omp wheel to mountenay boss?
2b_pablo
posted on 13/8/07 at 10:54 AM Reply With Quote
anyone know if they are compatible? both 6 hole ok just not sure on hole spacing.
ta
Marcus
posted on 13/8/07 at 11:19 AM Reply With Quote
I don't think they're compatible, Mountney has much larger PCD, saying that, the Mountney M range uses the smaller spacing.
Marcus
Because kits are for girls!!
2b_pablo
posted on 13/8/07 at 11:44 AM Reply With Quote
car is at home but from memory the pcd is a bit bigger than I remember my momo being.
nps mate cheers
shortie
posted on 13/8/07 at 12:14 PM Reply With Quote
You will need an adapter, Demon Tweeks sell then.
Ring them and tell them what you want to go from and to and they should be able to sort you out.
About £20 from memory.
Rich.
2b_pablo
posted on 13/8/07 at 12:19 PM Reply With Quote
a boss is only £34 so Ill prob buy that then sell my mountenay wheel with boss included.
thanks for the info lads.
posted on 13/8/07 at 04:48 PM Reply With Quote
As said it depends on the Mountney wheel. The older ones used a large boss that is not compatible. The newer Mountney 'M' range have a boss that is compatible with the OMP, Momo, Raid etc. wheels.
