Author: Subject: which wishbones?
Martian
posted on 27/8/07 at 02:26 PM Reply With Quote
which wishbones?
i need some lower wishbones for my locost. where is the best place to get them? i was looking at some on e-bay, but they were not like i have been advised to get. might be going to donnington on 16th
caber
posted on 27/8/07 at 02:46 PM Reply With Quote
It depends exactly what you want. most manufactured ones do not have enough caster angle as has been said many times. It is not too difficult to make your own but build a strong steel jig to make them in, look at the new book it explains it all very well.
Caber
posted on 27/8/07 at 03:58 PM Reply With Quote
Lower ones don't have any castor built into them, they are usually equal sided so they can be either side. What have you been advised to get? An example would be handy so someone can tell you if they have similar items.
SeaBass
posted on 27/8/07 at 04:57 PM Reply With Quote
Try Martin Keenan? Explain you have an early set of his wishbones that have bent in use??
Avoneer
posted on 27/8/07 at 05:59 PM Reply With Quote
Try Martin and say your after a new pair of wishbones and pay him properly.
Pat...
SeaBass
posted on 28/8/07 at 04:42 PM Reply With Quote
Pat...
Touchy touchy. I didn't mention anything about payment now did I Pat?!!
posted on 28/8/07 at 04:54 PM Reply With Quote
If that is really the case, then by all means.... However, if it is untrue then that is just plain wrong
Phil
zilspeed
posted on 28/8/07 at 09:08 PM Reply With Quote
That is the case with our Mr Seabass.
No big deal, it happened, it's fixed.
posted on 28/8/07 at 10:11 PM Reply With Quote
It may be the case with Mr SeaBass but is it also the case with Mr Martian??
If not, then do you not think it is wrong to ring MK and explain that he has an early set of his wishbones that have bent in use??
Or maybe I've misunderstood something or misread the advice that SeaBass has offered........
Phil
SeaBass
posted on 31/8/07 at 09:16 AM Reply With Quote
Originally posted by Hellfire
Or maybe I've misunderstood something or misread the advice that SeaBass has offered........l
Yeah I think maybe you have...
Fb999999999
posted on 31/8/07 at 03:29 PM Reply With Quote
Do it Urself!!!!!!!!
www.lora.c4.fr
