Author: Subject: Front caliper alternatives..
takumi
posted on 28/8/07 at 08:19 PM Reply With Quote
I'm thinking about front calipers, and dont want the expense of wilwood replacements, nor do I want the dead weight of the sierra calipers..
Are there any modern'ish OE calipers that are a close enough fit to work on a Sierra upright with a std sierra soldi disc.?
tak
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special valves FR22 cam, 4- 1 header.
carpmart
posted on 29/8/07 at 11:21 AM Reply With Quote
I cant answer your question but I will encourage you to re-consider not buying some new calipers!
Willwood do some cheap calipers which are only about 90 quid from rally designs including VAT. Got to be worth that kind of investment?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Bob C
posted on 29/8/07 at 11:25 AM Reply With Quote
I used the dynalite single calipers (on mx5 uprights). Those calipers are 1.4lbs weight each (!) and cost about £60 apiece. Operation is excellent
Bob
takumi
posted on 29/8/07 at 11:33 AM Reply With Quote
I know what you mean, I was just wondering if anyone had tried others, I know some people are using vw golf rear alloy hand brake calipers, mountings only out by 1 or 2mm..
Maybe some exist somewhere for the front..
Raldes have a nice kit for a Sierra donor at £200 for powerlites, I'm assuming thats a pair !? What exactly comes in the 'kit' two calipers+mounts, discs, + pads?
Trev Borg
posted on 29/8/07 at 09:41 PM Reply With Quote
This is the exact same thing i was looking at. I am going to fit bigger wheels, so i don't mine if the calipers stick out a little.
Was looking at either fitting bigger disks and using the original calipers spaced off, or better calipers, or both.
i keep watching fleabay
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
SyKaTurbo
posted on 30/8/07 at 08:27 AM Reply With Quote
I'm using Puma calipers. Just need a spacer washer machining to make them fit. The discs are alot lighter than the Sierra. Not sure if the calipers are though.
