Author: Subject: Spring
takumi
posted on 30/8/07 at 07:53 AM Reply With Quote
Spring
Hi
I have my coilovers at around 50 degrees from horizontal..
What rating of springs should I be using..
It has a Zetec-s engine, so not too much weight up front..
thanks
tk
RobinHood 2B 2.0i pinto, Keihin 38mm Carbs, lightened flywheel, O'Mori remote filter kit, 10 row oil cooler. Modified head, 10.2cr, special valves FR22 cam, 4- 1 header.
procomp
posted on 30/8/07 at 08:22 AM Reply With Quote
Hi whith that sort off angle and not much other info try 300lb-350lb to start with.
cheers matt
