The Doc
| posted on 7/9/07 at 09:45 AM |
Self Centre Issues
Like so many others I seem to have little or no self centreing. What is a reasonable toe-in?
Can someone advise this as the approximate difference in millemeters between the rear distance and the front distance between wheel rims or tyres?
I have standard escort rims and standard 155 13s on for the SVA
graememk
| posted on 7/9/07 at 12:20 PM |
to sort out he sc on my indy with sierra uprights i had 2deg toe out and 30 psi in the front tyres.
but they are all different.
locoboy
| posted on 7/9/07 at 12:50 PM |
smidgen toe out and 40psi for me
Locoboy
| posted on 7/9/07 at 12:52 PM |
If yours is a book locost and you made your own top wishbones, I'd strongly recommend that you make another pair with the correct back-set built
in.
The standard design puts the centre of the top joint about 14mm behind the bottom one. If this is set further back to 22-25mm then your castor is
pretty much correct and self-centering just happens naturally.
Much better than faffing about! Makes driving much nicer as well.
