oadamo
| posted on 9/9/07 at 03:16 PM |
front hubs
hi what would be the lightest setup to use on a kitcar would it be cortina ones
without going into stupid money. can you buy just the stub bit to have a go at making your own. or is there a scrapyard Alternative.
thanks adam
RazMan
| posted on 9/9/07 at 03:35 PM |
The Raceleda jobbies are probably the lightest
Raz
Mark Allanson
| posted on 9/9/07 at 03:36 PM |
You can buy the stub from many places, fabricating an upright with corrected ackerman and using rosejoints should be a moderately simple job.
oadamo
| posted on 9/9/07 at 03:40 PM |
has anyone used the stubs off the sierra ones. can it be done.
adam
Confused but excited.
| posted on 9/9/07 at 05:17 PM |
A search on here should reveal some designed by a gentleman called Rorty, using 20mm square, 3mm thick wall RHS.
