Author: Subject: p clips
Furry
posted on 19/9/07 at 05:07 PM Reply With Quote
p clips
probably a silly quetion but what size p clips has everyone used to secure their copper brake and fuel pipes. also can you use one rivet to hold two pclips, as not only will it look tidier when the pipes are running parallel, it will also reduce the amount of holes i have to drill in my nice new powdercoat.
[Edited on 19/9/07 by Furry]
donut
posted on 19/9/07 at 05:09 PM Reply With Quote
Yes P Clips mmmmmmmmm
scutter
posted on 19/9/07 at 05:40 PM Reply With Quote
I used these for my brake lines, availible from Merlin motorsport.
ATB Dan.
another_dom
posted on 19/9/07 at 05:49 PM Reply With Quote
Furry,
You need to choose a P Clip to suit the OD of the pipes you are using. This is typically 3/16" for brake lines, but varies a lot for fuel lines. You can certainly rivet them back to back at a single point for parallel runs.
I used the same as Dan for the brake lines, and nice neoprene jobs for my stainless fuel hose.
Dom.
[Edited on 19/9/07 by another_dom]
